shower drain pipe size reqs.
| Posted in General Discussion on June 8, 2003 03:40am
I have an existing upstairs bath which has served well for many years but now we want to install a shower and wonder if  the old 1.5 ” drain will serve or is it  not only code to have a 2″ but  truly advisable. Thanks
  1. Wet_Head | Jun 08, 2003 04:36am | #1
    truly advisable
    1. Piffin | Jun 08, 2003 04:42am | #2
      Most mine here only 1-1/2"
      why advise more?.
      1. Wet_Head | Jun 08, 2003 04:47am | #3
        less clogging but mainly because of some of the extremely high flow heads so popular these days... you know... the sunflower type.  10gpm!
          JeffBuck | Jun 08, 2003 08:52am | #4
          my plumber just told me the same thing last week...
          Both code and gooder....
  2. MojoMan | Jun 08, 2003 05:56pm | #5
    My plumber just explained this to me. Since a shower (only) doesn't ever get the big rush of water you get from draining a tubful of water, a 1-1/2"  drain is more prone to clogs. That being said, we shower rather than bathe in our tub with 1-1/2" drain 99% of the time without constant clogs. (Now that our long-haired daughter is home for the summer, that may change!) Now, I wouldn't recommend violating any codes, but if you are doing this for your own use and changing to 2" would be a big hassle and you use water conservatively, you might be just fine.
    Al Mollitor, Sharon MA
