Shower grab bar/ existing shower stall
AndrewG | Posted in Construction Techniques on May 9, 2005 06:53am
Fellow FHB readers,
My parents have asked me to install a grab bar in theri existing fiberglass shower stall. There is no access to the backside of any of the walls. Has anyojne created a method of secure achorage without in-wall horizontal blocking or, as I suspect, is this an impossibility? The best I can think of is (a) drill a hole sized for a toggle bolt (b) spry expandable foam into the hole so that it all expands below the hole (c) insert the grab bar with toggle bolt, sealing with silicone (d) drop mortar down into stud cavity from hole in wall above stall; the mortaar will be stoppped by the expandable foam and create a lareg ancharge around the toggle bolt.
Andrew Gil
Architect/ Builder
    JeffBuck | May 09, 2005 07:17pm | #1
    describe "no access" ...
    is it tight to a concrete wall ... or just there's some nice drywall in the way?
    I like to get a big hunk of lumber back in there ... slathered in silicon ... to glue it first.
    1. AndrewG | May 09, 2005 07:45pm | #3
      Good Question, JeffBuck: "No access" in this case is 450 year old plaster & lath on both sides of all walls. I though of an improvement over my first idea. There's a dnager in shooting mortar into the cavity from above teh shower stall, and that is the assumption that it will drop to aurround the toggle bolts. This potential failing can be eliminated by squeezing the mortar in through the togglebolt holes with a mortar bag. True, this still won't transfer the forces back to the adjoining studs as the proper detail would, but it will place a 4"H x 16"W block of mortar pushing against the back of a lath and plaster wall which might be enuogh.
      Andrew Gil
      Architect/Builder
    BillHartmann | May 09, 2005 07:39pm | #2
    Here is an anchor just for this application.
    http://www.wingits.com/%5EWingIts/home/default.asp
    Edited 5/9/2005 12:57 pm ET by Bill Hartmann
    DDay | May 09, 2005 07:59pm | #4
    Saw this on this old house, http://www.wingits.com/^WingIts/home/
    It is a similar to a toggle bolt but it has about 8 legs instead of just the two.  I think they will have something that is rated for fiberglass.
  4. Bowz | May 09, 2005 11:18pm | #5
    Andrew,
    Is there drywall above the fiberglass module? If you can locate a stud behind the drywall, then plumb down to where you need the bar, you can use a "Solid Mount".
    Available at http://www.grab-bar.com .
    To use the Solid mount, you drill through the fiberglass, and lag bolt a threaded piece to the stud. Then a mounting flange threads onto the part that is bolted to the stud.
    Bowz
    Joe | May 10, 2005 03:22am | #6
    I know this won't help in this case.  But, this is why in all my apartments, when I renovate a bathroom I spec 1/2" CDX plywood on all the walls under the plaster.  I can hang anything anywhere anytime.  No problem.
    1. AndrewG | May 10, 2005 04:07pm | #7
      Joe,
      I'm with you on that. I install 2x6 blocking continuously at counter height and towel bar height, but your solution has even more flexibility.
      A couple of people responded with links to "wingits.com". They make a fastener specifically for grab bars and grab bars tailor-made for heir fastener (of course). It looks like it will  work great, and trheir grab bars look like premium quality so I may be saved on this one.
      Thanks again,
      Andrew
  6. DanH | May 10, 2005 04:13pm | #8
    Wingits: http://www.wingits.com/
    I've used them several times, on both tile and fiberglass, and they've worked out well. The only "trick" is making sure that the place where you install them is clear of obstructions behind the wall.
    (Well, there is one more trick: Finding a dealer. Couldn't find one in Louisville, KY, eg.)
    1. AndrewG | May 10, 2005 04:47pm | #9
      Dan,
      Glad to hear that you had success with wingits. I've been through your problems even mounting towel bars, paper towel dispensers and toothbrush holders (the first anchor goes right in but he second one always ends up hitting a venty pipe, the back of a junciton box or somehting else!). I figured I'd have a problem finding a dealer, but I'm told they sell small quantities on-line. Besides, if the make high-quality grab bars modified to work with the fastener, I'm also counting on them includingthe fastener when I buy the grab bar.
      Thanks,
      Andrew
      1. DanH | May 10, 2005 11:43pm | #10
        Well, they're not going to include them for free.They know how much their stuff is worth (in terms of saved time/grief) and they charge accordingly. But it's good quality stuff.
Tool Test: You Need a Drywall Sander
We tried out a range of rotary and random-orbit sanders to compare their dust collection, quality of finish, and user fatigue after hours of sanding.
  • Sharp-Blade Solution
