Looking for help in finding code reference (NEC or IBC) that specifies covered trim for recessed light in shower.A local lighting store has been telling customers that an open trim with an exterior bulb is OK in a shower enclosure. I believe this is wrong, but I want to have specific references before I say anything. Thanks in advance.
Hi Normel
My local Electrical inspector (Electrical Safety Authority, Ontario Canada) told me to make sure I had a covered light in the shower and that it was on the circuit protected by the GFCI. He said he wouldn't want me to stick my arm up into the light while I was singing in the shower. Zap
Cliify
The shower light needs to be approved for wet locations.
Read the manufactures instructions to see what is required to make that fixture usable in a wet location.
Check the major manufacturers, they have approved housing and trim specifically designed for shower areas. Yes, you do need a cover, no bare bulb.
Typically, they are recessed and the cover/shade has a spring loaded function which holds it tight to the body, and a rubber gasket which acts as a seal.
Regards,
Boris
"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
I was going to mention that, and Boris beat me to it. I know Halo makes a model called AT (air tight) which includes a gasket. I'm not sure if its rated for moisture or not. I addition to the electricution angle, a light in the shower is a very common source of excess moisture in the attic or ceiling space above the shower.
Jim
Appreciate the replys, but I was looking for a specific code reference concerning the use of a covered recessed fixture in the shower.
1999 NEC 410-4 Fixtures in Specific Locations.
(a) Wet and Damp Locations. Fixtures installed in wet or damp locations shall be installed so that water cannot enter or accumulate in wiring caompartments, lampholders, or orther electrical parts. All fixtures installed in wet locations shall be marked, 'SUITBLE FOR WET LOATIONS". All fixtures installed in damp locations shall be makred, "SUITABLE FOR WET LOCATIONS" or "SUITABLE FOR DAMP LCOATIONS." {EMPHASIS ADDED}
This is exactly what is everyone has said.
You need to look at the fixture.
