In one particular double-wall design, the inner wall rests on the floor platform, as usual, but the outer wall rests on the sill. This allows insulation between the joist header and sheathing, to avoid thermal bridging by the floor joists. The double-wall can be assembled on the floor platform, with the tops of the two wall frames separated by the plywood plate at the top and by temporaries near the bottom. The assembled wall section is then raised to vertical using wall jacks. Obviously, the bottom of the outer wall frame will be lower than that of the inner wall by the height of the floor joists and subfloor.
The question that comes to mind is what the sill will consist of. As far as I can tell, without having a set of code books on hand, is that the sill may be a single layer of 2x PT wood, set on sill sealer and anchored in conformance with code to the concrete foundation. Width must be at least that of the wall frame mounted on it. In the case of the double wall described above, the sill would be 2×10, flush with the outer face of the foundation wall, or 2×12, overhanging so as to cover the top edge of exterior rigid foundation insulation.
However, I commonly see sills built up of a double layer of 2x. What is the requirement for thickness of the sill? What is the reason for a double layer? In the double-wall described above, the bottom plate of the outer wall actually will constitute a second layer of sill, although not bolted to the concrete with the first layer, and the floor framing would rest on a single layer.
As far as I know, the only reasons people use double sills are for extra height in the basement and possibly as an aid to achieving a level sill. I'm no aware of any code requirement to have multiple sills.
If I had the situation you described, I would use a PT 2x10 bolted to the foundation wall and frame on top of that as needed.
Jon Blakemore
I am not sure for the reason for the double sill, but the example of the double wall you mention sounds interesting.
Another option to consider for insulation at the rim is a is a SIP Rimboard. If you did in the archives of my blog in the july time frame, you'll see an example.
You may also like the T-mass foundation.
Adventures in Home Building
An online journal covering the preparation and construction of our new home.
