Do they make a coupling ( maybe compression ?) that I could use to join two kitchen sprayer hoses? I have a new sprayer & hose but I also have a 14″ deep sink & a broken rib so I am not at all wanting to stuff myself under the sink to change the hose. Thanks 🙂
Not a "compression" but a barbed insert with clamps.
Same hose as soda machine lines.
Problem being is the clamps getting through the hole in the sprayer insert that's in the sink.
*************I should be OK ( temp fix ) just joining the new 4' to the old though yes ? Run it the new through the simk hole & join below ? Bobbi
Sounds like it will be fine. Broken ribs are no fun. I think the worst part for me was trying to sleep.
Thanks. Yeah sleeping sucks. Having one arm too. And I managed to break a back one.Bobbi
If you're joining below then just put a new one on ;-)
The connection will be fine.
“We need to be a country of tall fences and wide gates.”
Fred Dalton Thompson
*****I'll fix it right as soon as I have two arms & can move again. No way I can reach up behind the sink for a while Bobbi
Good call. It's often painful enough working under the sink. I can't imagine what it would feel like with a broken rib.
**************I don't even want to find out either. This is one of those cases when good enough is going to be good enough ;-)Bobbi
There is no such thing as a simple plumbing question. I hope you got it answered!
Sure there is-------- When's payday?
Was Thursday. They changed to Fridays.
Somdays life is too complicated.
We actually get paid on Thursday if you get paid by mail.
I have direct deposit, so I get my stub on Thursday & credit to my account on Friday.
the only thing that sucks about direct deposit, is trying to have a check pool on the job.
PLUMBER TOLD ME"if it was simple, everybody would be doing it".two ways to screw up concrete 1) concrete driver 2) concrete finisher
That has some truth.
But some people can't handle dealing in peoples shid.
Blood born pathogens, hepatitis B & some other wicked things that can just flat out kill you.
***************I think I did. Going to head to the store in a few & check for parts. I do know there is no such thing as a simple plumbing project when it comes to me. Nothing ever quite goes as planned but at least I keep the guys at Ace entertained :-)
Bobbi
I'm looking at the first post? why can't you just put the new spray head on the existing hose?
*************The end connector seems to be different. The new head screws on & the other seemed to have snapped on. Of course it could have all been the same at one time with a portion of the old hose being tossed out with the old head.Bobbi
Take a look at the new one ? maybe possible to remove end and replace on old one.
they have a washer -if you pop it off sometimes under it is a little c clip may be able to swap with old.
Thanks. It's over at the house but I'm not but I'll look tomorrow. I did get a coupling & a clamp just in case. I only need for it to work for a couple of months & I'll fix it right. Also found out while checking things out that I have no hot water shut off valve so I'll add one & an instant hot water dispenser all at once when I can move again :-)Bobbi
