In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Simple (?) siding question
tab1 | Posted in Construction Techniques on November 20, 2002 07:14am
Not to stir up the Tyvek vs tar paper wars, but:
My first siding job is going to be putting up FC clapboards (I read the FHB #140 article) after removing a combination of cedar shingles and clapboards. There is presently tar paper over 1 x’s under the shingles. My first question is: Should I remove the old paper and replace it with new, just cover it over with new, or does it matter?
Second question: Because I’m putting on vertical corner trim, where there was none before, there will be places–like between the corner of the house and the edge of the garage door–where there will only be a couple of inches between the two trim pieces. Will it look best to cut very (!) short clapboards for these spaces, or perhaps just run a single piece vertically?
Thanks.
Thon
  1. Piffin | Nov 20, 2002 11:18pm | #1
    Just run the new TP over the old unless it is loose or buckling, which is usually the case.
    As to the shorties. I would still use clapboards but the danger is that pieces will split along the grain. I caulk first before setting each one so the caulk doesn;t show and then count on it to act as an adhesive while sticking the piece with a fine sized nail.
    "The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
    1. CAGIV | Nov 21, 2002 01:39am | #2
      piffin, I know it would be an utter pain the butt, but why not predrill the shorties to make sure they dont split?
      1. Piffin | Nov 21, 2002 02:39am | #3
        sure, that works too..
    teasea | Nov 23, 2002 04:32pm | #4
    if it was me I would remove the old tarpaper so you can inspect the sheathing for rot or any other unknowns
Getting Shed Dormer Elevation Right
Drawing a full-scale picture on a scrap of plywood can help get the ridge looking straight.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
