sink replacement doesn’t drain
ewog | Posted in General Discussion on April 16, 2007 04:56am
I replaced a double sink with a single sink and installed a new dishwasher in the kitchen that I am renovating. The new sink won’t drain at all. I can plunge the sink and it will empty but it still won’t drain.
The old sink/old dishwasher combo worked just fine. I had the drywall off and the sink is vented and hasn’t been changed since the house was built in 1979. I made NO modifications to the drain.
I am really stumped. Does switching from a double to a single sink make a difference? Is the new dishwasher causing an air lock? I’m clutching at straws.
    CapnMac | Apr 16, 2007 05:11pm | #1
    Any chance of a photo, like from a cellphone or the like?
    As a guess, the old double had the g/d on one bowl, which then connected across to the the "normal" trap under the other bowl, and the d/w drained into the tailpiece of the g/d.
    Now that there's only the one drain point, the possibility of an inadvertent "uphill" condition is middling high.  And, this winds up being a major pain in the posterior.  You often need to engage in cabinet surgery to go with the plumbing suregery.  All of which occurs with a 4-5" bend where human spines don't; while holding up completion of an entire kitchen (or worse yet, the frustrated impatient toe-tapping of SWMBO for taking so [expletive] long . . . )
    There was a recent thread on whether two traps were ok, if you care to search for that (some good photos in there, along with a great deal of good solid theory on draining kitchen sinks).
  2. Shacko | Apr 16, 2007 05:45pm | #2
    Did you change the depth of the sink when you replaced it?, if so the drain may be too high with the new install. If the dishwasher is installed with a high drain loop or air-gap that should be o.k. Do you have a garbage disposal, new or old? Something has changed, but I can't help without more info.
    "If all else fails, read the directions"
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
