Sizing a compressor
shady | Posted in Construction Techniques on March 27, 2003 06:05am
Hey all,
I’m about to buy a compressor and was looking for advise on what the smallest compressor, in terms of CFM and PSI, I can buy that will comfortably handle a framing nailer for a one-man framing crew.
Also any brand name advise also welcome,
  1. CAGIV | Mar 27, 2003 10:36pm | #1
    I can't advise psi or cfm, but a pancake compressor should be fine, I use a PC pancake to run my framing gun and finish nailers
    Not bad, but if I bought new I would get one that one uses oil, the oiless are a lot louder, and from what I have heard, do not last as long.
    Try the advanced search, I remember a discussion about this sometime recently
    View ImageGo Jayhawks
    1. shady | Mar 28, 2003 05:25am | #3
      Hey thanks for the reply, I did an advanced search and found some good discussions.
      1. Handydan | Mar 29, 2003 08:17am | #4
        As long as you can carry it, afford it, and have enough power to run it, bigger is better.  I have a small oiless from costco, which works fine, but it is noisy and runs a lot more often than the five horse craftsman.  But it is nice to be able to move it with one hand.   I think that tank size and high pressure can help make it last longer under full time use, and like all tools ;  with luck you get what you pay for.
        Dan
        1. shady | Mar 29, 2003 02:32pm | #5
          dan,
          very sound advice,
          thanks
  2. Steve1 | Mar 27, 2003 11:34pm | #2
    the little pc pancake unit that runs at 150 psi should be big enough and portable too
    i have the older run that runs at 100 and have stapled plenty of underlay down with it
    steve
  3. Turtleneck | Mar 29, 2003 06:25pm | #6
    I would say the compressor should put out a minimum 4cfm at 90psi. If you want to bang nail or staple you may  have to wait for a compressor of this size to catch up. If you will be doing any work in cold weather don't get an oilless cold weather is hard on an oilless.
     Turtleneck
    Its not a smile- its a cramp
    1. shady | Mar 30, 2003 03:42pm | #7
      Turtleneck,
      I'm a pretty methodical worker (read slow).
      I appreciate the stats and the heads up about oil.
  • Stop Ice Dams When Reroofing
  • Outdoor Lighting
  • Eichlers Get an Upgrade
  • Picture-Perfect Pergola
