Sizing for a chimney
HowsDoin | Posted in Energy, Heating & Insulation on October 12, 2005 08:22am
Hello,
I’m New here, so I’ll start slow.  I’m replacing the heating & hot water system in my 2 family house.  I have two seperate units for heating, and 2 units for hot water.
My question is:
I have an 8 inch (type B?) chimney that runs up from the 1st floor through the 2nd floor and out to roof.  A total of about 15 feet end to end straight up, no 90s, but a 45 at the bottom.  I need 1 95,000 BTU boiler, and 1 195,000 BTU boiler.  I want to keep 1 of the old hot water tanks that’s 65,000 BTU and add a new one that’s about 40,000 BTU.
I know all this won’t fit in the existing chimney, so I’m thinking of hooking up an indirect heating tank to the boiler as an added zone, but only if I have to (too much $$$).  How do I figure out how much BTU the chimney can handle?  If I extend the chimney will it increase the capacity?  Is there different vent pipes that I can run from the boilers to the chimney that will increase the capacity?
Thanks in advance, Hows
  1. Tim | Oct 12, 2005 05:38pm | #1
    Hows,
    Welcome to Breaktime,
    For gas fired appliances, 15 ft vertical rise, 395 mbh input rating total, you will need a 10" b-vent for the main vent up and out.
    Individual single wall connectors for each appliance will be as follows:.
    195mbh - 7", 95 mbh - 5", 65 mbh - 5", 40 mbh -  3".
    This is assuming that all of the appliance are natural draft, natural gas fired and that there is a 3 ft rise for each connector to the main vent.
    "How do I figure out how much BTU the chimney can handle?  If I extend the chimney will it increase the capacity?"
    I use the manufacturer's (Hart & Cooley) tables for b-vent sizing. Go to their website and you can download the application guide for yourself.
    http://www.hartandcooley.com/vent/all_vent.htm
    Vertical height increase will increase the capacity of the flue. Changing an 8" from 15' vertical only to 20' vertical only will increase the capacity from 365 mbh to 405 mbh, enough to accomodate all of you proposed appliances, but do really want an extra 5 ft of pipe sticking out of the roof?
    Tim
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
