I used to use the sidewinders. I bought a Skil M77 worm-drive and I started to like the saw. The menu
says that the lubricant should be changed after the first 10 hours. That’s fine, but it doesn’t say how often I should change the oil after that.
It also says that I should check the oil level every time I use the saw. Do you check it every day? Please advise. Thanks.
Checkin' the oil once a week would be plenty (and about 52 times a year more than most guys check it).
*You mean to tell me my 77 has oil in it? Damn, better check that.....:-) Seriously though, what with all the sawdust, any oil leaks are going to be painfully apparent. Sam
says that the lubricant should be changed after the first 10 hours. That's fine, but it doesn't say how often I should change the oil after that.
