I have a friend that recently had some shoddy slab work done in his crawl space to where the floor drain in the middle of the floor is higher than the four corners . The space is roughly 10 by 10 and he needs water to flow to the middle to the drain . what type of material would one use to float out the floor to accomplish this ? The lowest spot is an inch or so .
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
Shabby? That sounds like standard slab work!
He'll have to do an overlay. Check out Scoffield systems.
Thanks Ill googole that .
Jim I thought Scofield was a concrete stain mfgr. I think what he needs is a topping compound, something that can go from an inch to feathered and not self-level. I think Ardex is one mfgr. A good tile supply house or masonry supply might have more options."Put your creed in your deed." Emerson
Presuming this is to drain to daylight: Maybe find where the low spot really is, and put a new drain there? Even if you're expecting large amounts of water, the existing drain would take most of it, the new drain only the last inch.
-- J.S.
There is no way to install a new drain without jackhammering the concrete and that is want he wants to avoid at all costs . Im confident that surfacing the slab will work just fine . Thanks guys.
