I have to install some slate tile on a front entry porch here in Michigan. I was wondering, the cement porch is in good shape no cracks or pitting, what additives should I use to counteract the affects of frost/freeze here in MI. Or is there a special mix available designed for exterior use? Also, what type of sealer has worked best with you (i.e silicone) Thanks for yoour help.
http://www.mapei.com
