Looking for advice / reference material on hillside building. We are at the onset of the idea development phase to convert approximately 38 sq meters (~400 sq feet) underneath our concrete deck. House situated on severe slope. Additions may include spa, second bedroom/study.
Avoid rot and split wood by positioning butt joints on a flat block with a dado for drainage.
Builder’s Advocate: An Interview With ViewrailRelated Stories
Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
Podcast 551: Members-only Aftershow—Badly-Built Homes
Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
Pick up the current issue of Fine Homebuilding. Look at page 74.
A HILLSIDE CABIN'S UNLIKELY ADDITION
by Parker Platt
A three-story tower solves steep-site problems by bringing the house to the cars
View ImagePreview this article
It sounds like you are talking about going in under the lower side of an existing, is this right? Do you have any digital photos you can share?
If so, and you do any digging, you need to have an engineer study the soils and give you a plan first. I am assuming that there are enighbors close by so soil pplacement on removal and directiomn of water flow as you re-direct drainage will also be an issue to plan for.
Thanks for the suggestions. Correct - lower side of existing structure. We bought the house last year, so need to assess strength of existing structure as part of the process. Some digging probable. Neighbors not so close, but drainage on these slopes is a vital issue. Current drainage on underside needs repair, in any case. Definitely bringing in the engineers on this one! Have attached two photos
only life affirming platitudes allowed -Doud '07
Would a full cluster of enemies be called an enema? -Piffin
