Smooth Wall Touch Ups
etherhuffer | Posted in General Discussion on March 1, 2007 12:05pm
Any pointers on fixing dings in smooth walls? Fill and sanding block?
www.etherhuffer.typepad.com
    MrSQL | Mar 01, 2007 12:29am | #1
    lite weight spackle (doesn't shrink)
    1. etherhuffer | Mar 01, 2007 12:40am | #2
      Sand after with 400 and a block?http://www.etherhuffer.typepad.com
      1. IdahoDon | Mar 01, 2007 07:06am | #4
        I like the pink spackle that turns white when dry.  Sand flat and feather edges with 120 grit paper on a 10" sanding block.  Prime with a quick dry primer and small roller.  Look for flatness and respackle if needed.  Paint.
  2. DanH | Mar 01, 2007 12:41am | #3
    I love the premixed, solvent-based spackle known as "Ready-Patch", from Zinsser. Adheres well, goes on to a feather edge, dries quickly, sands easily.
  3. dovetail97128 | Mar 02, 2007 06:06am | #5
    spackle or dry wall topping mud.
    wet/damp sponge to finish and clean up over patch area.
    It will resoften the mud and let you blend it .
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
