smoothiing textured drywall
atj | Posted in Construction Techniques on July 6, 2004 09:31am
has anyone tried to smooth out textured drywall with a skim coat of mud? im wondering how hard this is. i am assuming it would be cheaper to do this than tear out the drywall and replace it with new…
thanks for any tips
  1. calvin | Jul 06, 2004 02:43pm | #1
    Depending on the texture that is there now, I would scrape off any hods, perhaps sanding, to eliminate the stuff that would cause the knife to bump.  The PC dustless power sander does a good job at this.
    I would then use a setting type compound, original durabond.  This dries very hard, if not adept at skimming, I would advise using all purpose bucket mud for the first coat as it has a bit more adhesive than topping or easysand.  I usually apply coats in opposite directions to even up the finish.
    On some older textures, I've used plaster weld to increase adhesion.
    Quittin' Time
Picture-Perfect Pergola
