Soffit install – should I be concerned?
diverdavid | Posted in General Discussion on October 3, 2010 07:21am
We had new gutters and aluminum soffits/fascia installed on our home about 4 years ago and I discovered this weekend that none of the original soffit material was removed and that the new soffit was simply installed over the old. Is this common practice or should I be concerned. Since the install, we’ve had issues with ice dams and a lot of icicles that we never experienced before so I’m wondering if perhaps the double layer somehow restricts the normal venting/airflow and has led to the new issues? Any advice would be helpful.
  1. DanH | Oct 03, 2010 07:25am | #1
    Yes, it's common practice, and yes, you should be concerned.  We had a neighbor who had his rafter tails rot out as a result of this.
    (I'd be concerned about the quality of hte soffit work as well -- likely it's poorly installed and allowing rainwater to get behind it.)
  • Fine Homebuilding's Author Guidelines
