I need to patch a hole atop indoor 4 inch soil pipe. Seems I’ve heard various opinions regarding the fix but seems a cast iron saddle looks typical/suitable. Divergent opinions as to need for rubber gasket and putty. I figure based on these I ought to use the rubber gasket and plumbers putty (over the entire width & length of the gasket – or simply around the perimeter of the hole). Wondering what advice I might get here?
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
How did the hole get there?
Seems irrelevant, but since you asked... it was drilled and about 1 inch diameter.
I think I'd use a rubber gasket, a piece of sheet metal, and some spiral hose clamps.
You do need to be careful to get it gas-tight.
What would ensure that?
A good tight fit, a reasonably pliable gasket, and maybe some gasket cement.
Great! Thanks!
