Has anyone used solid surface veneer either from Wilsonart or the other companies? Is it that much less (its advertised 70% less) than the true solid surface?
Mike
Mike
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
Mike, I used the veneer in my last house. It looked great. The problem I had was the glue released. You can not put anything hot close to it or it will release and bubble the material.
Thanks Brent
Mike
