Solving Vibrational Problem
KenfromCanada | Posted in General Discussion on April 5, 2009 05:37am
This question may have been posted before, so please direct me to the thread thanks
Second floor front load washing machine vibrational problem transfering through floor framing members.Washer is level in all directions What’s the best solution? Reframe or increase blocking etc. , pour a slab of concrete (increase mass) or isolate with rubber damper blocks like they use on industrial machine (source?)
Ken
  1. mike_maines | Apr 05, 2009 05:48pm | #1
    We just installed these http://www.gviinc.net/index.shtml for a customer with the same problem.  I haven't heard yet how well they work.
    It's always tough to find a good location for a second-floor washer.  The farther away from the bedrooms the better.  Increasing the mass would dampen vibration but try the rubber pads first.
  2. [email protected] | Apr 05, 2009 09:56pm | #2
    The isolating feet can be acquired from most industrial or tool room suppliers.
    Reid Tool, Graingers, MSC, McMaster-Carr, etc. should all have them in stock.
    Or, Ebay:
    http://cgi.ebay.com/Air-Compressor-Anti-Vibration-Pads-Industrial-Quality_W0QQitemZ270358372087QQihZ017QQcategoryZ42875QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    http://cgi.ebay.com/LOT-NEOPRENE-STEEL-VIBRATION-ISOLATION-PADS-4C974A_W0QQitemZ380114346044QQihZ025QQcategoryZ92150QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    http://cgi.ebay.com/BALLMOUNT-VIBRATION-ISOLATORS-SET-0F-4_W0QQitemZ180341998261QQihZ008QQcategoryZ42912QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    The last one could be made up from some 1X4 and 4 super balls.
    The best solution is to quit over loading the washer.
  3. DanH | Apr 05, 2009 10:07pm | #3
    Yes.
    But before you do anything else make sure all four feet are TIGHTLY against the floor so that you cannot by hand rock the machine in any direction AT ALL.
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
