sound absorbing loose fill insulation?
Matt | Posted in Energy, Heating & Insulation on October 1, 2008 03:24am
Anyone heard of or seen or used a granular type loose fill insulation that is supposed to be really good at absorbing sound?  Sorry – I don’t have any more info.  Just a vague discription from a RE agent.    He said he saw it used in some tract housing in Las Vagas that backed right up to a highway.
  1. BillBrennen | Oct 01, 2008 04:37am | #1
    Matt,
    I wouldn't call it granular, but cellulose loose fill insulation is very good at absorbing sound. When I switched my attic from fiberglass to cellulose the difference in traffic noise getting inside was astounding.
    Bill
  2. Steinmetz | Oct 03, 2008 07:46am | #2
    VERMICULITE at a masonry supply. I used to bore 1" holes into the tops, bottoms and lock and hinge mounts (mortises) With a steel rod,through the holes, break out the usually cardboard inside grid work.
    Using a funnel,pour the stuff in and bounce the door to settle the material down.
    Add as much as you can get in, then plug the holes with corks. Turn the door around and fill from the bottom ,plug ,then the sides etc. etc.
    When you knock on the (Now quite heavier) door, it won't sound hollow any more. Acoustic tiles added to the outers will deaden the sound even more Steinmetz.
    1. reinvent | Oct 11, 2008 01:31pm | #3
      It would be a lot easier to buy a solid core door.
Two Ways to Test Windows
  • The New Old Colonial
