Replaced cast-iron sink with SS Elkay and client is not happy, or used to, the noise factor. Any thoughts on making it quieter? I was thinking of sticking some peel and stick (Grace) wherever I could as that may help.
Undecoating from an auto parts store.
Chuck S
Brush on truck bed liner might work also.
Brian
Sink is already installed. I recall, from back in the day, that stuff was real messy, and what is the set up time?
I would almost rather uninstall it and re-install than to work with most of this stuff upside down and over head.Other thoughts are tube caulk geocell or silicone.
or spray foam from a can
I actually did that once. Customer insisted on a HD SS sink and I tried to tell her that the noise was gonna be a problem. A week after the installation, I pulled it and painted on some bedliner. - lol
He's (the homeowner) is going to try some or one of the thoughts posted here. Thanks...
My S10 truck hood was vibrating, sprayed a can of 'great stuff' all over it, damped out the noise pretty good.
Auto body supply should have these or something similar, use something like a laminate roller to install
http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=26636&utm_source=googlebase&utm_medium=cse&utm_term=FIB116&utm_campaign=googlebase_18u
or from a car stereo store, Dynamat has several possibilities, sheets or paint on
http://www.dynamat.com/index.html
Everything will be okay in the end. If it's not okay, it's not the end.
That's a neat idea....Thx
scraps of torchdown have worked well for me... apply heat with a plumbers torch and stick em on.... i used this on the sides of cabinets where a dishwasher went... made a huge difference...
p
Thx's
I had most of a gallon (the only size I could buy) of sealant left over from when I installed my dust collector. Used it to apply several coats along with some fiberglass cloth and mat left over from some other projects. DW was very pleased.
Paul
