Source for 2" or 3" paddle …
| Posted in General Discussion on November 22, 2000 01:53am
Anyone know where I can get a 2″ or 3″ (wide) paddle (also called spade) wood boring bit? Actually, it is to be used for boring through 8″ thick AAC block, but found that wood bits work OK – just cant find one that big. The holes need to be bored for vertical rebar reinforcement. Then some loose pea gravel concrete will be poured down the holes.
A hole saw won’t work because of the depth of the hole (8″) and I’m not too keen about the prospect of burning up a $40 forstner bit.
PS: AAC = Airiated Autoclaved Concrete – lightweight concrete that cuts/drills, etc like wood. It is a relatively high R-value building material.
  1. Matt_G. | Nov 22, 2000 01:53pm | #1
    Anyone know where I can get a 2" or 3" (wide) paddle (also called spade) wood boring bit? Actually, it is to be used for boring through 8" thick AAC block, but found that wood bits work OK - just cant find one that big. The holes need to be bored for vertical rebar reinforcement. Then some loose pea gravel concrete will be poured down the holes.
    A hole saw won't work because of the depth of the hole (8") and I'm not too keen about the prospect of burning up a $40 forstner bit.
    PS: AAC = Airiated Autoclaved Concrete - lightweight concrete that cuts/drills, etc like wood. It is a relatively high R-value building material.
