Any one experienced in installing hot tubs or spas? If so, what labor do you typically charge and what difficulties do you experience.
Thanks.
Thanks.
Listeners write in about attics, foundations, and dodgy electrical devices. They ask questions about trusses, wet ceilings and siding installs.
how big...
what's the location..
need eletric brought in..
need water brought in...
need a crane to get it to location.
need a base of some type installed...
lots of varibles to consider here...
WOW!!! What a Ride!
More'n I want to count or remember.
Shouldn't say that, all of them were pretty good jobs for mostly decent customers. Just plenty of work back before I was smart enough to know that the boss has to get paid too.
So, I have all of IMERCs questions, too.
Oh, and a make-up-your-mind one, spas & whirlpools are pretty much synonymous; hot, or soaking, tubs are a different animal--two different sorts of goals/plans/results. That is, if you're trying to get it "right."
One does not want to swap the very nice hand-coopered soaking tub for the FG whirlpool--or vice versa--even as a "learning experience" . . . (The one thing I did not have, that I needed/should have had for business, was a spot with each of the types of things available--hindsight is so very sharp.)
