Split face block comm. bldg. leaks
| Posted in Construction Techniques on September 8, 2003 02:07am
Hi,
I have a 5 year old 5,000 SF commericial building with  split face block exterior.  We have had some problem since new with seepage at the floor (it’s all drywalled inside) and exterior drainage has been ruled out.  I hired a commercial builder to build this building and he doesn’t think it is the roof, flashing or parapets(the roof is steel). Before the building was painted, we had alot of water wicking thru the block and I think this may be whats is happening now.  Most of the problem occurs at the back wall and I expect the gutter is overflowing and sheeting down the wall after a heavy rain.  The side walls are 20′ high and it is a pain to check the gutters for leaves and pop bottles, etc.  The builder  cut the ends of the gutter lower in an effort to make them “self cleaning”
I called an architect friend and he recommended elastomeric paint.  I talked to the builder and he said they used a block filler and many coats of latex, but he did mention “pin holes”.
Any ideas before we repaint?
Thanks,
Bob
  1. eborg2 | Sep 08, 2003 04:55am | #1
    Is the block filled with anything?  Grout, vermiculite insulation, foam?  How about weep holes and flashing at the wall base?  Is water running down the inside of the block wall or seeping through?
    Post any information you can on this regard.
    Eric
    1. triplenet | Sep 08, 2003 05:23am | #2
      Eric,
      There is no insulation in the block.  Walls are furred out metal studs w/ fiberglass batts.  I don't think there are weep holes.  I'm doing this from memory as the building is 300 miles away.
      Bob
  2. toast953 | Sep 08, 2003 07:59am | #3
    bob,   in your post you mention, parapets, and back wall. My question is, what type roof design so you have?, If I threw a dart at your problem, I hit water entering at the roof deck/ masonry junction and running down on the inside of the block cores. Did I mention that I'am no good at darts. Jim J,, How high is your finished floor above exterior grade??
    1. triplenet | Sep 10, 2003 06:26pm | #4
      We've had a roofer there and he seems to think things are all right. Metal wall cap is in place.  Floor level is above grade except at front and rear door.  We had a painter look at it yesterday, but haven't heard back yet.
      Bob
        SamT | Sep 10, 2003 06:46pm | #5
        What is the weather there?
        Hot and humid outside, AC inside?
        Cold outside, warm and moist inside?
        Condensation?
        SamT
        "You will do me the justice to remember that I have always strenuously supported the right of every man to his opinion, however different that opinion may be to mine. He who denies to another this right, makes a slave of himself to his present opinion, because he precludes himself the right of changing it."   Thomas Paine
        1. triplenet | Sep 10, 2003 07:11pm | #6
          It's in central Kansas, hotter than XXXX in the summer.  Interior is Office use with HVAC.  Problem occurs after heavy rain.
          Bob
        2. Totalhome | Sep 10, 2003 09:47pm | #7
          Here in Chicago Lots of new 3 flat condo buildings have been built using single 8" split face block for the sides and back. The fronts are usually a nice face brick.
          Almost all of these buildings have weepage/ leakage problems through the split face block. Most often the owners are told to do a periodic coating of a masonry sealer (every year or two) to reduce/ eliminate the leakage.
          Find a good mason. It seems that the split face block looks nice but is to porous to be the sole barrier to the weather.
          Jim
          1. brownbagg | Sep 11, 2003 02:25am | #8
            I had the same problem. Three coats of a waterproofing paint.
Fast, Accurate Wall Framing
