spray foam
| Posted in Energy, Heating & Insulation on May 14, 2008 04:07am
Like everyone else in North America, I am trying to step up the insulation in my home before next Winter hits. I am looking to buy a spray foam system that I can use to tighten things up. I am not looking for something that I will be doing lots of houses, probably just mine.   Any suggestions? Open cell, closed cell?
Don’t want to spend a fortune doing it but don’t want the HomeDepot insulation in a can either.   Any suggestions??
    talkingdog | May 14, 2008 10:27am | #1
    tigerfoam.com
    Probably not cheaper than hiring a pro to do it, plus
    you are subjecting yourself to the intense toxicity of
    uncured foam.
      Jeff_Clarke | May 16, 2008 03:53am | #3
      This is what we have - http://www.ncfi.com/residential.html
      Amazing stuff.
      Temperature dipped into the low 40's the other night.  Inside stayed in the high 60's ... with NO heat on.   For 10 hours.
      1. timothyo | May 16, 2008 08:10am | #4
        A couple of thoughts when you compare foam to other forms of insulation.
        On the positive side:
        1) most closed cell foams strengthen the structure substantially
        2) most sprayed in foams do a great job of cutting air infiltration On the negative side
        1) price-- compared to blown in cellulose blanket, the best bids I have seen are about four times the price-- or more.
        2)fire-- most of these foams are ridiculously flammable and must be covered with sheetrock or some other fire/flame retardant
        3) diminishing returns-- most of these foams do a great job when you apply 2 inches, but have seriously diminishing returns after that. That is why foam is often coupled with blown in cellulose, blown fiberglass or standard FG batts.
        4) Pollution and indoor air quality-- some of this stuff is better and some of it off-gasses really awful chemicals that will affect the overall environment and your indoor air quality.I am building a house for myself and have looked at all of this pretty hard. There are good reasons why a lot of the more experienced builders on this site (and some of the greenest of the green builders) like cellulose. Check it out.
          Jeff_Clarke | May 16, 2008 04:16pm | #5
          The NCFI insulation does not support combustion - in other words if you take a piece and hold a lighter to it the foam self-extinguishes.
          Edited 5/16/2008 9:16 am ET by Jeff_Clarke
          1. timothyo | May 16, 2008 06:19pm | #6
            It looks interesting. I will check into it further.
        2. Willy50 | May 17, 2008 02:48pm | #7
          Thanks for all the info and input.
          I guess the perfect spray foam insulation would be non toxic, non flammable and as inexpensive as conventional insulation, cellulose etc.
          Thanks all
          1. BigBill | May 17, 2008 05:31pm | #8
            Have you looked at this?
            http://www.airkrete.com/
          2. timothyo | May 18, 2008 08:47pm | #9
            I have looked at this and I have read up on it online. It looks like a great option, but I don't know anyone who has actually used it. Have you? It is written up as efficient, environmentally friendly, fireproof and very stable. I have seen nothing on the costs.Do you have any experience with this product?
            Jeff_Clarke | May 19, 2008 06:32am | #10
            R-3.9 / inch (airkrete) doesn't cut it.
      2. Clewless1 | May 21, 2008 10:35pm | #11
        bogus web site, dude. ?
          Jeff_Clarke | May 21, 2008 10:42pm | #12
          No - it's legit.  They must be having problems today.
  2. reinvent | May 14, 2008 01:53pm | #2
    First see if there are installers in your area.
    http://www.icynene.com/LocateDealer.aspx?country=1
    http://www.biobased.net/dealers/find.php
    http://www.insulstar.com/installers.html
    http://www.corbond.com/find_installer.htm
    If you have no luck with that then go the DIY route.
    http://www.rhhfoamsystems.com/
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
