Howdy all.
I’m 2 months from finishing my house, and I’d like to explore having sprayed in place foam on the underside of my roof, but I cannot locate anyone who does it.
Any experience here? Any contractors close to western MD? Is it worth it? (the rest of the house is ICF, 10/12 pitch, 1700s.f. small area of house in scissor trusses)
Otherwise its blown in fiberglass, and I’d prefer to not go there, especially to keep the hvac ducts inside the conditioned space.
http://www.corbond.com/find_installer.asp
or for DIY
http://www.tigerfoam.com/index.php
BTW, if you are just now planning the insulation, you are probably further than two months from finished
Thanks for the vote of confidence. I've been planning for a few years, just at the insulation fork in the road... but one path seems impossible. The tiger foam website is something I will look into; I have 25 squares of roof to insulate, and the estimate was $7500, partly because the guy was going to drive 5 hours to do the job!
Treat every person you meet like you will know them the rest of your life - you just might!
Edited 10/31/2005 11:20 pm ET by Brian
Another DIY site for suppliers was fomo
Thanks. I once thought the DIY approach would be outrageously expensive, but now that I have an estimate from an installer its looking better...
Brian,
I used SIPs laid flat on my ceiling.. They span a tremendous distance and are wonderfully efficent as an insulation.. If you are worried about wire chases etc. just raise your ceilings a few inches and then put a false or lowered ceiling back in..
Brian,
Call Corbond yourself. Talk to Blair Johnson and he will direct you the best he can.
The website is sometimes out of date. I install Corbond and am located in western Massachusetts, a little too far from you.
Good luck, and you will not be dissapointed with the Corbond. It's the best insulation available.
Stu
Thanks. I'll call Monday.
