Does anyone have a source for square-headed machine bolts, about 1/4 x 3? Or are they just not made anymore?
Thanks – Jeff
Thanks – Jeff
Check over at the forum on keenjunk.com, I think some of those guys will even hand forge bolts to order for high end reproduction work.
*Jeff, you gonna make me go out and look in the coffee cans? I know I can come up with some. Might have something (wood/metal) attached. How bad you need em?
*McMaster Carr supply company. These guys have pretty much everything you'll ever need. Just went to see if they have the bolts your looking for and they do. I don't know how to link but here is the address.www.mcmaster.com scroll down the page to "Fastening and Sealing". Click "Capscrews and Bolts" then "Bolts".Hope this helps.CM
*Thanks, CM, a hardware supply company found them for us from the same source (McMaster). Application is to replace through-bolted strap hinge hardware on a c. 1820's barn. Hex heads just don't look right.Jeff
*They sell them in our local HD, I bought some recently.
Thanks - Jeff
