Square socket wrench
achome | Posted in General Discussion on June 12, 2006 08:35am
OK it’s not homebuilding but I thought somebody might have a suggestion..
Had to work on my rototiller yesterday. Needed to add to the transmission gear oil.  You need to open up a plug in the side of the transmission and add oil till it starts to run out. Those square-headed drain plugs, however, are a nuisance. You can’t fit a normal socket onto them, as the sockets are star-shaped or hex-shaped to accommmodate a hex head. This plug was 3/8″ and a 3/8″ open end is rather short, so there’s no moment arm for torque… and then it slips off, rounding the corners!  A larger socket strips it too.
So I had a revelation…3/8..hmm. that’s the drive side of my socket set. So I took a 3/8 female to 1/2″ male adaptor and my big crescent wrench and got the crescent on the 1/2″ male and got it off!!! Yippee!!
But does anybody know where I can find a set of sockets that are square as opposed to star or hex?  I can’t locate anything on the web.
Johnny
    BossHog | Jun 12, 2006 08:49pm | #1
    Sometimes a 12 point socket will work on a square not. Other times a crescent wrench or open end wrench works fine.
    If all else fails go for vise grips.
    If the world didn't suck, we'd all fall off. [My Son, Carl]
  2. Snowmon | Jun 12, 2006 09:06pm | #2
    Here's the fancy way:
    http://www.thetoolwarehouse.net/shop/SK-19781.html
    MarkH | Jun 12, 2006 09:21pm | #3
    An 8 point socket will fit.  Sears has them.  Sears item #00944222000  is a 1/2" drive 1/2" 8 pt.
      xxPaulCPxx | Jun 12, 2006 09:28pm | #4
      Exactly, that's where I got mine from.
      You also use them to unbolt square nuts on fences and sill plates... after a healthy spritz of PB Blaster.Rebuilding my home in Cypress, CA
      Also a CRX fanatic!
    2. pm22 | Jun 13, 2006 06:02am | #17
      I thought or heard that evil* Sears/Craftsman discontinued this item. But indeed the item is an eight [8] point socket. Wright tools makes them. But you have to go to a real tool store to get them.
      ~Peter, former photographer for the Sear's bra ads but I took the Playboy approach
      *Sear's has a double standard guarantee. They state on all their advertising and receipts "Satisfaction Guaranteed or your Money Back" but if you are not satisfied [for instance your new pair of jeans you bought from them has no zipper], they WILL NOT give you your money back.
  4. DanH | Jun 12, 2006 09:46pm | #5
    Check with Sears or a farm implement store. Look for "eight point" sockets.
    1. achome | Jun 12, 2006 09:59pm | #7
      Thanks guys-
      I'll check out the local sears for some 8-pt sockets.  My original craftsman set has served me well for about 25 yrs so far.
      Johnny
      1. QCInspector | Jun 12, 2006 10:23pm | #8
        I believe one of the names they go by is Weatherhead sockets or something similar. I got 8 points from Craftsman and 4 point from the Snapon truck from when I turned wrenches as an aircraft mechanic.
        1. DanH | Jun 12, 2006 10:38pm | #9
          While we're on the topic, does anyone know of a source for some oddball plumbing wrenches. I need to remove a check valve retainer ring, and it requires an X-shaped wrench with about a 3-inch diameter.
  5. DanH | Jun 12, 2006 09:48pm | #6
    Another option, if the problem is simply reaching the plug with a regular wrench, is a "crow's-foot" socket. It's handy to have a set of these around anyway, and they don't take up much room in the toolbox.
  6. JohnSprung | Jun 12, 2006 10:43pm | #10
    If you just need one size, not a set, and it's OK if it's not pretty, just drill the appropriate size hole in a piece of steel bar stock, and file it out to make it square.  I've done that a few times for special tools.
    -- J.S.
  7. toolbear | Jun 13, 2006 03:33am | #11
    Want square sockets?
    Snap On has them. Have a set in my rollway. They fix on 3/8 drive.
    Also have a set of farmer sockets. Might also check Craftsman catalog.
    The ToolBear
    "Never met a man who couldn't teach me something." Anon.
  8. User avater
    IMERC | Jun 13, 2006 03:36am | #12
    just about any place that sells sockets will have 8 point sockets...
    WOW!!! What a Ride!
    1. DanH | Jun 13, 2006 03:45am | #13
      Odd, I couldn't find them at Target today. ;)
        IMERC | Jun 13, 2006 03:59am | #14
        at Walgreens or Eckards either I bet...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      MarkH | Jun 13, 2006 05:02am | #15
      I couldn't find them at WalMart either!
      Just kidding!  I won't go there anymore.
        IMERC | Jun 13, 2006 05:11am | #16
        but they do have them...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Two Ways to Test Windows
  • The New Old Colonial
