In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
square tapered columns
KarlK | Posted in Construction Techniques on August 31, 2004 09:58am
I want to replace the generic colonial posts on my porches with square tapered columns on top of brick bases, in the Arts and Crafts style.  How do I set up my table saw to get a tapered, mitered cut?
Thanks!
Karl Kaminski
  1. TJ | Aug 31, 2004 10:15pm | #1
    I'm not a joiner, but my visualization of a tapered, square post does not suggest the mitered angles change pitch through the length of the taper.
    Therefore (unless I'm wrong), setting the tablesaw to the required angle - still 45-degrees - and running the piece using a taper jig ought to work.
    If the posts are going to be painted anyhow, consider eliminating the miter, and just doweling or biscutting the joints. Or join the edges with a running rabbet.
    -TJ
  2. emaxxman | Aug 31, 2004 11:00pm | #2
    I don't know what angles you would need.  However, it was mentioned to me that miter corners on wood columns would be a bad thing.  The problem seems to be due to wood movement over long joints.  Over time, cracks would appear.
    I know that doesn't answer your question directly but it does give an argument for not using the mitered corner.  Personally, I think the mitered corners are sharp looking.  I would love to see your results if you take that route.
  3. eggdog23 | Sep 01, 2004 12:05am | #3
    For a true arts and crafts column, you just want a taper, not a miter.  Two sides will have a slight reveal.
    Aaron
    1. KarlK | Sep 01, 2004 01:21am | #4
      Thanks for the suggestions!  You saved me a lot of work (I've got 10 to build)- I'll leave a reveal and biscuit the panels together.
      Karl
Using Liquid Flash at a Wall-to-Foundation Connection
Brian Pontolilo demonstrates how to air-seal where the concrete foundation, mudsill, and ZIP System sheathing all meet.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
  • Fastener System for Solving Deck Fascia Board Expansion
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
