Stairwell Painting Question
jimmiem | Posted in General Discussion on May 15, 2008 05:57am
My wife has asked me to paint the stairwell leading to the second floor of our 2 story colonial. Any suggestions on the easiest way to do it without having to get any special staging, planks, etc.  I’ve got a 24 ft extension that I could probably get into the house also an 8 ft step ladder and some 8 foot scaffold planks.
Any suggestions would be appreciated.
Thank You
  1. maverick | May 15, 2008 06:15pm | #1
    couple of options
    one is a long pole with a paint brush holder. takes a little practice but its not as bad as it sounds
    the other is lean a ladder against the adjacent wall and run a plank from the stairs out to it. put a cripple under it if its too bouncy
    also a little giant ladder is great for stairwells. you just extend one side longer than the other. tie if off for safety
    1. jimmiem | May 15, 2008 08:30pm | #2
      Thank You. Great reason to get the Little Giant.
    hammer1 | May 15, 2008 08:41pm | #3
    Take your 8' step ladder and set it on the stair in the closed position, leaning against the upper stairwell wall. Put a saw horse or similar at the top of the stair and run a plank from the top of the step ladder to the horse.
    1. jimmiem | May 26, 2008 03:09am | #13
      Worked great.
      Thank You for the tip.
        hammer1 | May 26, 2008 03:45pm | #14
        Geez, you didn't get to have a new ladder!!? The plank is a lot easier unless you have a wide open staircase.Beat it to fit / Paint it to match
        1. jimmiem | May 27, 2008 05:18pm | #15
          I really wanted to but here's the problem.  Several years back I asked the person roofing my house what length ladder to get so that I could reach the peaks for painting, etc.  He said to get a 36 footer.  I did but it's not too easy to move around by myself so I figured I'd get a 32 footer to make life easier. So I couldn't justify the little giant when I need the 32 footer more.
          But the step ladder and plank worked out just fine.  I already had the plank so I figured I was ahead of the game.
          1. peteshlagor | May 27, 2008 06:03pm | #16
            I bought one  of those little giant type ladders once.  POS.  Broke the first time I used it.
            The best all around ladder I've come across (and it works very well in stairways) is a 8' Werner combination ladder.  An adjustable stepladder that can be used as an extension ladder.  Perfect for cutting in that ceiling line waaay at the top, without the bouncing of the plank.
          2. jimmiem | May 27, 2008 06:58pm | #17
            Now you tell me.  But the plank did not bounce...full 2 inches thick...and I don't weigh too much.
  3. PhillGiles | May 15, 2008 09:14pm | #4
    I have a Jaws ladder (the original little giant, but better); wouldn't use anything less.
    The edging tool from Richard (a pad with wheels on the edge) works very well on a telescoping pole BTW.
    Phill Giles
    The Unionville Woodwright
  4. frammer52 | May 16, 2008 12:59am | #5
    Hire someone else!
    1. jimmiem | May 16, 2008 03:29am | #7
      My feeling exactly.  My wife retired from her day job and is on a roll to paint the house.  I get to do the hard to reach places.
      1. frammer52 | May 16, 2008 03:32am | #8
        I have an idea, she is retired she should do it!
        1. HomeSolutions | May 16, 2008 03:41am | #9
          No because ther would be no reason to buy a Little Giant what fun is that with no new tools.
          1. frammer52 | May 16, 2008 03:47am | #10
            The fun is in owning not useing, unless I can buy one of those neat airless sprayers!
          2. jimmiem | May 16, 2008 07:08pm | #11
            I felt the same way and thought there was something wrong with me.  Glad to know I'm not alone!!
        2. jimmiem | May 16, 2008 07:11pm | #12
          She is, but wants some help with the high/tough areas.  Sounds fair to me.  when I tell her I'm going to set up a ladder/staging she says no. I told her the other choice was for me to grow wings and fly up there.  She said use an extension pole..I'm a little leary and would probably drip paint all over the place.
  5. HomeSolutions | May 16, 2008 03:26am | #6
    LITTLE GIANT or thre are knock offs of the litlle giant, just as good and a little cheaper if it will not see use everyday
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
