steam shower
Carlos | Posted in Construction Techniques on June 29, 2005 05:17am
Dear experienced tilers:
I need your help to settle an argument.  I’m installing a steam shower and have been given two suggestions on how to prepare the floor of a steam shower –
#1, 3/4″ plywood subfloor, drain flange, mud, cement board, mud and then tile which is later grouted and sealed.
# 2, same as above but vinyl membrane between flange and first mud.
Both tilers assure me of their arguments.  Anyone out there have experience installing a steam shower and can help settle this argument before I go the wrong way and have to tear out a big mistake?
Carlos
    EricPaulson | Jun 29, 2005 11:30pm | #1
    Wow, what's the one guy thinking not installing a liner???
    Just gonna let the water drip through the floor??
    Many ways...........
    Sub floor, tarpaper, pre-slope, liner membrane, (edit)clamp drain assembly to membrane, mud base, tile.
    Shcluter makes a system that will water proof that guys mud base with no liner beaneath. The Schluter System waterproofs from on top of the mud base.
    http://johnbridge.com/vbulletin/index.php
    http://www.tile-experts.com/proddetail.asp?prod=KK82152%2FE
    [email protected]
    Edited 6/29/2005 4:31 pm ET by Eric Paulson
  2. Shacko | Jun 30, 2005 12:04am | #2
    Hate to say it, but eric paulson is right.  Your #2 idea is the best. Luck be with you.
      EricPaulson | Jun 30, 2005 12:54am | #3
      ......gettin' better with those font shacko...........way to go!
      If you look at the little grey horizontal bar above where you type the post there is a button labeled SIZE.
      You can choose your font size there. This is size 1.
      EricI Love A Hand That Meets My Own,
      [email protected]
      1. Shacko | Jun 30, 2005 11:33am | #4
        Like I tried to say no matter what size I select when I click post it may come up an entirely different size when it goes through.  I sometime have to select size 5 or 6 times before I get any size at all.  This only happens on the Breaktime forum. Every one I ask has no ideas what is causing this.  You have any thoughts?
          EricPaulson | Jun 30, 2005 01:49pm | #5
          Likely your browser. But I'm no techie.
          What you are using now is not offensive, but in bold it becomes a bit annoying to others as well as myself.
          You could always try forums help.
          Have a good day.
          [email protected]
          1. Shacko | Jul 01, 2005 10:09pm | #6
            Thanks for the info. I'll check it out. You have a good one also.
Tool Test: You Need a Drywall Sander
We tried out a range of rotary and random-orbit sanders to compare their dust collection, quality of finish, and user fatigue after hours of sanding.
  • Sharp-Blade Solution
