Steam Showers Anyone ???????????/
Woody78 | Posted in Construction Techniques on February 14, 2005 04:30am
Has anyone done a steam shower recently?
Is it necessary to do a mud pan or can you get by with good quality acrylic pan as long as the 3 walls and ceiling are tile over concrete backer?
                -would a 6mil vapor barrier behind the backer be helpfull, or are there other materials designed for this
                  -what  about the height of the nozzle? do you have to get it up high away from the acrylic?
                 -if done in conjunction with a standard shower inthe same enclosure are 2 doors preferable. the inside one a standard shower door the outside gasketed ?
any tips welcomed including guidance to published info
    IMERC | Feb 14, 2005 05:28am | #1
    you serius about that being a steam shower????
    or would it be a steam room or bath....
    steam hower my be a bit brutel...
    WOW!!!   What a Ride!
      Woody78 | Feb 14, 2005 01:45pm | #3
      its a combo fella
      we dont have alligator skin,
                   an even they are sensitive
                   thanks
  2. onthelevel | Feb 14, 2005 07:35am | #2
    I don't know why an acrylic pan would not work. We build ours with a hand poured mud base like any other shower. the door does not have to be that tight. 1/2 inch gap will work. the steam generators put out a lot of steam and you don't have to be that air-tight. Poly against the studs (or tar paper) would be great to keep moisture from the studs. Try to install an exhaust fan with a timed-on switch directly in the room if possible. I have one where the customer's cleaning lady insists on keeping the door closed. Two days later you open the door and there is still water hanging on the ceiling! All I do is open the door for a day and it is gone. Good luck
Drafting the 2027 IRC
  • The New Old Colonial
