Stone Spliting
jimcco | Posted in Tools for Home Building on November 25, 2006 11:17am
I had a lot of Sandstone monoliths 2-5 ton range and 90% burried. Some of these were 24-30″ thick & 5’x10′ . I took peoples advice here & got a 1″ Bulldog SDS Plus. & Bosch good 3/4  x 10″ bits. That combination really socks holes in the sandstone. Then got stone splitting shims & wedges (3/4″ x4″ from Trow & Holden website. Putting holes every 6″ across this stone will split stuff I would never have believed.
  1. dedubya | Nov 26, 2006 01:36am | #1
    I use a lot of trow and holden feathers and wedges been
     saving up my spare change to buy a set of rhino carbide
    tools, been eyeballin a nice deposit of limestone ledges
    the last few weeks just havnt had the time to get my
    chicks in a row yet.
     plus  Santa is bringing a digital camera to the ole homestead
    this year  maybe I can post some quarriyng/ stone dressing
     pics later on.if the signs are right.
      Sphere | Nov 26, 2006 04:55am | #5
      Dewayne..you still up for a trip to here in KY? Just south of Lexington.
      It'll be inside rock work. Warm, buddy, warm.
      I have irriatable Vowel syndrome.
      1. dedubya | Nov 26, 2006 05:31pm | #7
        check your email- keemosobee?
          Sphere | Nov 26, 2006 05:40pm | #8
          Will do.
  2. gstringe | Nov 26, 2006 01:49am | #2
    Never tried to split sandstone but all the sandstone I have seen here in the West is so soft, you can gouge it with a stick. I took an old Milwaukee big honker roto hammer down a river on a raft trip one time to mount a plaque on a rock many years ago. The roto hammer was 100v but we had an 80 v battery pak that would drive the drill better than ac. All the rock in the area was sandstone and turns out we didn't need the big heavy roto cause the sandstone was so soft. We recessed the plaque so as to try to avoid someone getting a tool behind it and prying it out. The recess we made was done with a plain old screwdriver, just scraping it out. Last we knew it was still there after many years.
    I like your approach....now lets see your departure
    1. jimcco | Nov 26, 2006 02:01am | #3
      Ya, I've seen some of that soft sandstone but this stuff here in Oklahoma is as hard as the hardest limestone when dry. 200 million years old and keeps this bluff standing streight up like limestone.
      I'll try to get some pix of the next big one I split.
    zak | Nov 26, 2006 03:19am | #4
    Those are nice tools.  I've used the same ones.  For the really big rocks (vw beetle and up), you can get wedges and feathers where the wedge fits in a pnuematic jackhammer.  I think we used wedges and feathers for a 1 1/2" hole.  That really goes fast.  The hard part is getting the jackhammer up to the wedge.
    zak
    "When we build, let us think that we build forever.  Let it not be for present delight nor for present use alone." --John Ruskin
    "so it goes"
  4. ponytl | Nov 26, 2006 08:03am | #6
    i have carved a bit of limestone.... really easy to work and carve... regular cheap harbor freight wood working tools do a nice job.... plus it's kinda fun... print out what you want on our printer... use one of those patern markers for sewing... (steel toothed wheel)  run it over your paper patern on the rock... and it's just connect the dots after that...
    p
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
