strange breaker problem
brucet9 | Posted in General Discussion on May 9, 2008 01:48am
1970 vintage house, 12ga copper wires, 20 amp duplex breaker.
Tenant complained that a breaker for a circuit in the garage was tripping frequently sometimes when not much load on circuit. They have a fridge, guitar amp and music synthesizer computer plugged in.
I was all set to replace the breaker when I found the hot wire connected to it had burnt insulation 1/2″ back from the connection. I found that the terminal screw was loose and the copper was blackened where the screw contacted it. Wire on the adjacent terminal showed no damage.
I cut the wire back, beyond the damaged insulation, stripped 3/4″ and screwed it tightly in the breaker terminal. I did not remove the set screw in the breaker to burnish it nor did I try to clean out the inside of the terminal opening.
Everything worked fine at first, but now, one month later, tenant reports the breaker tripping again.
Can frequent over-heat tripping [from arcing at loose terminal] have weakened the breaker or is there something else I should be looking for?
Thanks,
BruceT
  1. segundo | May 09, 2008 02:35am | #1
    the more times a breakler is tripped, the weaker it gets.
    it could very well be that it has been tripped enough that it is weakened to the point of significantly less capacity and is tripping frequently although it is not being overloaded.
    oh, and it might rain.
    1. brucet9 | May 09, 2008 10:06am | #4
      Thanks, but "it never rains in Southern...California"Your location in your profile sounds like part of a line from Dr. Suess' "Sleep Book". I had to read that to my kids so many times I still can recite passages 15 years later.
      BruceT
    BillHartmann | May 09, 2008 02:43am | #2
    There might be internal loose connections inside the breaker that generating the heat that damaged the wire insulation.
    1. brucet9 | May 09, 2008 10:07am | #5
      Thanks,Bill. Looks like a new breaker is in order.
      BruceT
  3. DanH | May 09, 2008 03:43am | #3
    Due to the bad connection the breaker is overheating. Replace it.
    (The bad connection may have started as just a loose screw terminal, but now the terminal is corroded and possibly even the weld inside has gone bad. Just as likely the weld went bad first, causing the screw terminal to overheat.)
    What is wanted is not the will to believe, but the will to find out, which is the exact opposite. --Bertrand Russell
    1. brucet9 | May 09, 2008 10:10am | #6
      Thanks, Dan.I thought the first time I could avoid trying to find a replacement breaker for a 40 year old panel.At least it's not Zinnsco or PushMatic.BruceT
      1. DanH | May 09, 2008 02:07pm | #7
        Consider swapping breakers with a circuit with no load on it.
  4. sledgehammer | May 09, 2008 07:44pm | #8
    With the wire being loose you have been basically welding between the wire and the breaker. I wouldn't trust the breaker to hold the wire correctly.
    Replace it.
Picture-Perfect Pergola
