I got involved in a progect refinishing a table and the wife and I tried this citrus stripper product. Didn’t seem to phase the 19 yr. old finish, Do I need a different stripper?
![](https://images.finehomebuilding.com/app/uploads/2024/07/16151624/01232580-building-matters-expect-unexpected-thumb-16x9.jpg)
Don't buy in to the TV show nightmares—when you uncover something unforeseen on a remodeling project, take these steps to keep the process moving and fix the issue.
It's called sandpaper.
I hate it when that happens!Do they have any that smells like oranges?
I have a brand that rhymes with oranges, no I don't, nothing rhymes with oranges.
Name of the product you tried?
If you haven't, try CitriStrip made by W.M.Barr & Co., Memphis TN.
Try Walmart.
Odds are a quality solvent based methylene chloride semi-paste stripper will work fine, if you don't have reservations about using it.
Last thing I'd care to do is sand it all off.
Methelene Chloride will strip skin off your hand--a single coat will remove that stuff down to bare wood in about 30 minutes.Regards,
Boris"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
Sounds like that would strip a Playboy Bunny faster than your eyes could
" a single coat will remove that stuff down to bare wood in about
30 minutes."Yup. And that's why it's about all I ever use. Strippers containing MC, I mean. Time is money in the shop and I don't usually have the time nor the patience to f*rt around with slower strippers.Knowledge is power, but only if applied in a timely fashion.
Hi
When using strippers, make sure it is designed for wood. A methylene chloride stripper should work. You don't say where you are stripping the table, If in the garage and temp is low then the time will be much longer. One trick we used was to coat the stripper on fairly thick, don't be stingy, and cover it with saran wrap to keep the solvents from flashing off. Give it time to work. They work by attacking the bond between the paint and substrate. Wood being rough it takes a little more time. Also the newer environmentally friendly (D-Lemonene) citrus based stripper trade off speed for safety.
Cheers
Mac
