Stubborn Furnace
toast953 | Posted in General Discussion on April 2, 2007 07:28am
Morning All,  I’am trying to bring a Forced Air, Propane furnace back into operation. It has been turned off for ten years. Brand is Day/Night, electronic ignition, symptons are/is, I turn  the T-stat up,  Pilot will light, burners will light, and then after about 20 seconds, the burners drop off ( ie flame height dimishes), then go out completely, furnace then goes thru same process, over and over.  Note, I cleaned entire unit, including burners, everthing looks good, ie wiring, and general condition of unit.  Any suggestions much appreciated… Jim J  ps- tenant moved out after ten years and used the wood stove, new tenant wants the convience of furnace.
  1. DanH | Apr 02, 2007 07:29pm | #1
    No direct experience with such a unit, but I suspect that the flame sensor isn't working. I vaguely recall tales of cleaning it with steel wool or some such.
    IMERC | Apr 02, 2007 07:39pm | #2
    Clean the flame sensor with a green scubby...
    WOW!!! What a Ride!
    1. toast953 | Apr 03, 2007 08:33am | #3
      Good Evening Dan H. and IMERC, I thank you, I will assume the Flame sensor is located  in the vicinity of the Pilot light. Jim J
        IMERC | Apr 03, 2007 08:39am | #4
        yup... more likely to be protruding into it or within an inch or two depnding on the type.....
        1. toast953 | Apr 03, 2007 09:10am | #5
          Got it, sounds like it real similiar to a thermocoupling, except in this case, no standing pilot no thermocouple. Electronic ignition, flame sensor.. thanks again!! Jim J
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
