In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Subfloor or not under T&G fir on porch
| Posted in Construction Techniques on May 3, 2003 09:57am
I just bought T&G fir flooring to rebuild my badly deteriorating covered porch.  I got it at a close-out sale and got random lengths.  I would like to keep waste to a minimum and not have cut these boards off at every joist.  Are there any suggestions out there to help me on my way?  I thought about a subfloor but thought it would trap moisture.  Or maybe placing joists closer together, as near as every 12″.  I’m not sure what I should do, any help will be appreciated.
        Thanks!
  1. Piffin | May 03, 2003 10:11pm | #1
    Do not use a ply subfloor.
    the place wheere this wood will rot first is where it is in contact with other wood. Add subfloor and that will be all of it. Keep it open on the bottom and it can dry that direction as well as above and you reduce the places rot can start - the spots where it is in contact with the joists.
    I eliminate butt joints as well because that end grain will wick up water and stay wet to be rot seeds. I use gorilla glue in the T&G joints to keep water out of there.
    What you might do to decrease your waste is to biscuit the butt joints together with gorilla glue which would also help seal them. Try to place such joints away from higher traffic areas and away from antricipated wetter zones.
    Of course, use PT framing and seal coat all six sides first before installing. I see fir floors on porches and decks lasting a minimum of fifteen years with little help. Keep it sealed and breathable and you could get a lifetime.
  2. RW | May 04, 2003 01:57am | #2
    Go get yourself a section of gutter and two end caps. The larger commercial stuff will give you a lot more room for your lumber. Put it on horses, fill with whatever preservative you're using. Instant dip tank. Cost you ten bucks.
    "The child is grown / The dream is gone / And I have become / Comfortably numb "      lyrics by Roger Waters
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
