Looking for suggestions on subflooring when using radiant heat and gypcrete. OSB, UDLX or ???? 3/4″ or 1-1/8″? Floor system will be wooden “I” beam. Never having done a system like this, do you prep the subfloor with a sealer or lay poly or felt?
Thanks, HV
A quick checklist for success with exterior coatings.
Looking for suggestions on subflooring when using radiant heat and gypcrete. OSB, UDLX or ???? 3/4" or 1-1/8"? Floor system will be wooden "I" beam. Never having done a system like this, do you prep the subfloor with a sealer or lay poly or felt?
Thanks, HV
