What size wire do I need to put in a 100 amp subpanel? jeffysan
I'm using #2 Aluminum SER cable for mine at the end of this week. Meets code in my area.
You can also help to keep the thread "alive", by responding to those who respond to you. Even if its just a "thanks". The more "traffic" a thread receives, the longer it remains on top of the list.
J. D. Reynolds
Home Improvements
If you're using aluminum wire then I like to to go with 1/0, which is rated for a full 100a even when embedded in thermal insulation. #1 is OK if run in uninsulated walls or through open space. Copper wire, #2 does it for both. These numbers are from Table 310-16 of the NEC.
#2 aluminum is rated for 90 amps @ 75 degrees, which is what new 100a terminals are (usually) rated. If the wire is embedded in thermal insulation then you use the 60 degree column and #2 Al is rated at 75 amps. People use it for this purpose (subpanels) but I'm not sure it would meet code, and I don't like it because it's undersized.
I think there is confusion about this because the NEC allows #2 Al to supply a 100a service, as long as it is adequate for the load, even though it is not rated for it in the Table 310. But I don't think this translates to other uses.
LEE
Edited 4/25/2007 12:47 pm ET by edlee
