I have a potential customer who has a sunroom with 10 pieces of 32″wide x 8′ long tempered glass in the roof and a wood frame keeping it all up there. The pieces are stacked 5 low and 5 above divided by what looks like a 2x that runs perpindicular to the rafters. It obviously leaks above this 2x that just catches all the water from the 5 upper pieces. The rest of it is poorly detailed also. He would like to re-do it and make it right re-using the existing glass. The weather/waterproofing on the wood “roof” pieces is pitiful and needs to be re-flashed or whatever. Ultimately I will wrap the “frame” with metal but I’m not sure how to detail it. Does anyone have a good resource(book,website,etc.) that might show some good water proofing details for a wood between glass situation like this one? Anything about proper drainage details for sunroom roofs, especially one that may have a frame piece that runs perpindicular to the direction of drainage?
If you’re going to be dumb you better be tough! — Ancient Southern Proverb
Baltimore, MD 21218
USA
tel: 410-366-1146
fax: 410-366-1202
No website to speak of. Call and ask for a catalog. Techs are very good.
seek out a guy here with the BT name - Kostello. He's done some nice work as you describe in the U.K.
Quittin' Time
There are one or two companies that advertise in FHB all of the time specifically for channels, seals, and hardware for sun room glazing.
