Anyone seen any GOOD non-commercial studies of expected life for the newer swaged o-ring fittings?
Anyone already had leak claims?
Is this the next polybutylene fitting disaster? (I had Witco stock in the 70’s, remember that all too well)
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
What is a swage O-ring fitting? Why if you are swaging onto copper would you need an O-ring at all?
We use Swagelok fittings by the bucket at work and don't have any problems. Some have been in service for 30+ yrs. with no problems. If your talking push to connect fittings we use those also on plastic tubing. Generally we limit them to muscle gasses (air/N2) where small leaks aren't the end of the world. For plumbing/heating I would use compression. This is based on industrial exp. only,not residential where cost is more of a factor.
Is this the next polybutylene fitting disaster? (I had Witco stock in the 70's, remember that all too well)
