I’m applying cast concrete capstones to a masonry wall at 7000′ in the Rockies. I’m concerned that the grout joints will absorb moisture, freeze
and crack. On a recent trip to the big city, I saw grout joints in capstones
filled with a synthetic material. Has anyone seen or used a product of this
type? If so, what is it and who makes it?
David
Dave,
Check out the epoxy grout thread.
http://webx.taunton.com/WebX?13@@.ee8e15c/5
Hope this helps.View Image
Epoxy grout may be your answer however it creates many tricky clean-up problems. Mapai makes it and I've seen it in many home improvement stores such as Home Depot. It may be very difficult to use with a pourous material like stone. You may also look at some latex modified grouts or various additives that are used for grout to withstand freezing.
I'm applying cast concrete capstones to a masonry wall at 7000' in the Rockies. I'm concerned that the grout joints will absorb moisture, freeze
David
