Table of relative R values???
Bruce | Posted in Energy, Heating & Insulation on March 1, 2003 08:02am
Can anyone point me to a table of relative R values for most types of insulation?  I’d like to figure out (or look up if I could) the $$:R ratio for the differing materials … FG batt, cellulose, polyiso, BIBS, etc.
Formerly BEMW
The High Desert Group LLC
  1. UncleDunc | Mar 01, 2003 08:22am | #1
    I can't tell from my notes exactly where I got this table. It may have been from JLC before they started charging. Sorry about the formatting. The second set of numbers, for the loose-fill types only, is density in pounds per cubic foot.
    Insulation Type R-Value per inch
    Loose-fill
    Fiberglass 2.2-2.9 0.5-1
    (dense pack) 3.4-4.2 1.6-3
    Rock wool 2.2-2.9 1.7
    Cellulose 3.1-3.7 1.5-2
    (dense pack) 3.4-3.6 3-4
    Batts
    Fiberglass 2.9-4.2
    Cotton 3-3.7
    Sprayed Insulation
    Polyurethane foam 5.6-6.2
    Icynene foam 3.6-4.3
    Wet-spray cellulose 2.9-3.4
    Spray-in fiberglass 3.7-3.8
    Foam board
    Expanded polystyrene 3.9-4.2
    Extruded polystyrene 5
    Polyisocyanurate 5.6-7
    Polyurethane 5.6-7
    Phenolic (closed cell) 8.2
    Phenolic (open cell) 4.4
    And here's a link to another table.
    http://csf.colorado.edu/forums/essa/2001/msg01286.html
    Edited 3/1/2003 12:25:31 AM ET by Uncle Dunc
    1. Bruce | Mar 01, 2003 08:57am | #2
      Talk about fast service ... thanks!Formerly BEMW at The High Desert Group LLC
A New Approach to Foundations
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
