I have a project where I can’t fit a typical gas water heater in the allotted space and am looking for other options. Can anybody give me some input on tankless models? I’ve only done one so far (a small Bosch model), but would like to hear some recommendations from you savvy dudes/dudesses.
I did a subject seach for ‘tankless/on-demand water heaters’ but didn’t get anything usefull. Is there another thread I should be looking for?
Thanks………
Research using different combinations of those words. There's a Library of Congress equilivant on the subject.
Space savings is one of the best reasons to go tankless. Energy efficiency and cost are not, in most cases. Make sure you check out the gas lines and venting situation before proceeding.
I use the search and it's a 1 in 10 that I'll come out on a find. I don't know why but it mostly doesn't work.
I did follow a couple of threads here with good banter on it, I'll see if I can find. First try was this.
Search Results0 messages found: Change search criteria? Search Messages
Here's a short one but there were more. http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=89051.3
Third try with just water heater resulted in 200 so try that and here's a couple
http://forums.taunton.com/n/find/findRedir.asp?webtag=tp-breaktime&mg=7EB36A15-E6AD-4923-852D-F4CDD9ADCADC
http://forums.taunton.com/tp-breaktime/messages?msg=80109.1
