I am going to be building an 8×50 covered but open porch for a customer so I have been looking at porches here in New England and I find that almost all fir decking is laid from the house out to railing as opposed to lengthwise. Is this a technique to expedite water removal, ease of removing snow or just tradition?
A standardized approach, quick-to-install hardware, and a simplified design make building custom casework cost-effective.
Could be all of the above. I might add that it may also look better and you would NOT have any joints with 8' runs. Shoot it in w/15 gauge SS nails(?).
thanks for the tip, I never thought of full lengths - good point
ASteve, Piffen was talking about doing that in Maine, and with the fir available an the market, he was having to go back and replace several pieces a year.
I just recently did a front porch for my stepson and used Tenduraplank. Liked it. Made of recycled materials, for the green in us. Just don't go into sticker shock!!
thanks for the tip on the synthetic stuff, I will propose fir to the customer and if they don't collapse at the cost, I will upsell the good stuff
I think you have it backwards. Sell the expensive stuff first, then the fir as a fall back! Good luck!!
Tendura was bought by someone, I can't remember who. The name is different now.
I used Tendura on my own small front porch 6 years ago. Its held up very well, especially considering I still haven't painted it yet.
correct-deck in Biddeford, ME
Thanks.
My lumber yard has it, but I couldn't remember the name. CRS disease.
It facilitates drainage.
Run that stuff lengthwise and I doubt it would last four years before major rot repair time.
Even running it perp to house, you need to be sure and preseal all six sides before installing.
all the fir t&g that i've seen goes from the house out
AND it is pitched from the house out
i would still do it just like the old ways... with 2 changes
first i'd only use ss fasteners (we have a bostich floor stapler and i can get ss staples for it
2d... i would back-prime and edge prime all the fir before i laid it, and i'd cover the joists with 30 lb felt to aid in drying the backside
Huh ? ? ?
carpenter in transition
if you have wood to wood it is hard to dry.... the felt works as a wick
ever take a deck board up ? if the joists are capped with felt , the bottom of the decking and the top of the joists are in pretty good shape...
no felt.... you will see a lot of rotMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
i don't think i have ever seen felt run over the joists on a deck tearout to know whether or not it helped.
good idea though.
thanks for the tip.
I have torn off or replaced decking several times on humdred year old decks and porches where they had used tarpaper over the joist. The joists themselves were almost always fine. The tarpaper protected them well for all that time.The decking itself only showed rot from the backside, immediately over the tarpaper, but my memory was that this was only in locations where water runoff or snow pile up were extreme.
I've done them with mahogany the last few times. Don't know what the long term difference will wind up being, but they seem to have weathered pretty well in the short run. A little pricey, but not as expensive as the synthetics.
Did one in grey colored T & G synthetic, I think it was tendura, about 6 or 7 years ago that has held up great, but it does look plastic, in spite of the marketing that says otherwise.
STeve
I second Piffin's input about pre-priming the fir before you lay it. Make sure to get all four (pain in the ####) sides or it will soak up moisture and either rot or mold. I've used Cabot's penetrating oil before and it looks awesome, better than painted, in my opinion.
Good luck. Rob
what is cabot's penetrating oil
is that the olde good standby semi transparent stain or different product
tar paper over the joists has served me well in Florida on my dock that is subjected to horrific sun and rain. Whereas everything else weathers gray and splinters, the covered edge of the joists retain the original color and integrity. BTW, these are pressure treated SYP.
