thinset thickness
CCI | Posted in General Discussion on March 2, 2008 04:29am
This may be a really stupid question but, is there a way to figure the thickness of a layer of thinset underneath a floor tile?
I am trying to calculate how much subfloor to put under my tiles to come close to flush with another floor.
For instance, if I use a trowel with a 1/4″ x1/4″ notch and push the tile all the way down will that give me a 1/8″ thick bed of thinset?  I assume so but I have been wrong in the past. More time than I care count actually.
Thanks.
    JDRHI | Mar 02, 2008 04:50am | #1
    Yer thinkin' about it too much man.
    Yes.....the 1/4" notch will give you roughly 1/8" thickness in the end.....give or take.
    Certainly within reason for "close to flush".
    More importantly is the type of tile you will be embedding when determining the notch of the trowel.
    Beware the bikini clad female.
    She may be interpreted as offensive.
    1. CCI | Mar 02, 2008 05:31am | #2
      I know about checking the tiles for which trowel to use but I have to build up the floor anyway so I figured to get as close as possible to flush.  I was wondering if when the ridges are "flattened out" if they just fill in the grooves or if there is some "left over".  I guess that works with depth and width the same but not with 1/4"x3/8", etc. trowels.
      I am quite anal with that stuff since i hate being off just enough that it is a problem but not enough that I can blame it on the materials.
        JDRHI | Mar 02, 2008 06:19am | #3
        Preaching to the choir brother.
        My 100 yr. old home has 3/4" T&G plank subflooring. When I bought it 14 years ago, I added a layer of 3/4" ply to help stiffen and flatten its imperfections.
        3yrs. ago....prior to tearing out the carpeting and installing the hardwood flooring I realized that the tile floor I had installed in the kitchen was going to be 1/4" higher than the hardwood floors. So I installed a layer of 1/4" ply to my entire first floor.
        You wanna talk anal? I'm ALL over that! LOL.
        Best of luck.
    2. plumbbill | Mar 02, 2008 07:23am | #4
      ROFLMAO
      OK it took me a second to figure out yer tagline------ how many days left?
      “The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
        JDRHI | Mar 02, 2008 09:26pm | #5
        Supposed to be tomorrow, 3/3.
        1. plumbbill | Mar 02, 2008 10:32pm | #6
          Can you read any of the tav like Bob & Ron could on their mutual timeout a while back?
            JDRHI | Mar 03, 2008 12:29am | #7
            Nope....doesn't even show up.
          2. plumbbill | Mar 03, 2008 01:17am | #8
            Well you haven't missed much other than the usual pizzin matches between myself & the usual suspects. ;-)
            JDRHI | Mar 03, 2008 06:14am | #10
            Yeah....it's just the reason for the suspension that pizzed me off.
            A picture of a chick in a bikini.
            Same chick, wearing similar garb, as several others posted in the same thread.
            Their pics were deleted, and they received a warning.
            I got no warning....just the boot. All because someone complained to the mods.
            And I think I know the Mary responsible for the complaint.
  2. JeffinPA | Mar 03, 2008 01:42am | #9
    It might be a shade more than 1/8" but I'd assume 1/8", build up your subfloor and then set tiles.
    When you get to the door opening, check with level and if you need to, cheat up a few tiles 1/32 or so to give you what you are looking for.  So long as you are not using a square cut marble with no grout line, you should not notice if you cheat it a little.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
