Through the wall a/c condensation
onthelevel | Posted in General Discussion on May 14, 2008 06:26am
I know this is not a new problem, but I am sure looking for a new answer.  In a typical through the wall air conditioner, I am having problems with the outside can (through the wall mounting chassis) conducting cold to the inside, sweating when it contacts the warm air , condensing and causing mold on the sheetrock.  Yes I know an insulated box would help, but how can you accomplish this 3 stories up? Has anyone had this problem and come up with a solution?
  1. BUIC | May 14, 2008 10:24am | #1
     Place an insulated box over the interior face so the warm air can't connect with the cold sleeve?     buic
    1. onthelevel | May 14, 2008 04:13pm | #2
      Thanks BUIC, hadn't thought of covering the inside? I wonder if that is something the mfr. would have?  I have 13 of them to do.
      1. BUIC | May 14, 2008 11:28pm | #4
          I don't know if anyone sells them.
          I made mine out of 1x4 and 1/4" ply. Lined with 3/4" foam and it slips over the molding around the sleeve.  Two screws hold it on nicely.  Painted to match the wall...buic
        1. onthelevel | May 15, 2008 02:21am | #5
          Thanks Buic, we talked about your idea at lunch and are going to play with it a little!
    2. DanH | May 14, 2008 07:05pm | #3
      Unless it's very tightly sealed that just makes the problem worse. The problem is not the warmth of the air but it's humidity. The box needs to be a vapor barrier more than it needs to be insulated.
      What is wanted is not the will to believe, but the will to find out, which is the exact opposite. --Bertrand Russell
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
