Tile Article by David Hart
| Posted in General Discussion on September 12, 2001 09:25am
I’m sitting here thumbing through an old issue of FHB (May 2001) and am reading the article on tiling by David Hart.
I am real curious why Mr. Hart describes in detail why you should use sanded grout versus unsanded grout for grout spacing over 1/8″, and especially for floor tiling with a wider than 1/8″ gap, and then proceeds to grout the floor tiles with an unsanded grout. Problem I see is in the article photos he is clearly using unsanded grout on the floor tiles (which have a wider gap than 1/8″). The photo shows clearly that he is working on the floor tiles, and shows the bag of unsanded grout he is using right beside his mixing buckets.
Is there a particular reason he is using the unsanded grout instead of the sanded grout?
Just curious…
James DuHamel
  1. James_DuHamel | Sep 12, 2001 09:25pm | #1
    I'm sitting here thumbing through an old issue of FHB (May 2001) and am reading the article on tiling by David Hart.
    I am real curious why Mr. Hart describes in detail why you should use sanded grout versus unsanded grout for grout spacing over 1/8", and especially for floor tiling with a wider than 1/8" gap, and then proceeds to grout the floor tiles with an unsanded grout. Problem I see is in the article photos he is clearly using unsanded grout on the floor tiles (which have a wider gap than 1/8"). The photo shows clearly that he is working on the floor tiles, and shows the bag of unsanded grout he is using right beside his mixing buckets.
    Just curious...
    James DuHamel
Choosing a Paintbrush
  • The New Old Colonial
