tile atop very uneven slab
alrightythen | Posted in General Discussion on June 30, 2006 09:21am
I recently looked at a job that has a 7 foot crawl space with a poured slab.(very bad-unlevel-was poured like crawlspace instead of treated as basment pour) owner would like to put tile down, and was planning to shim the floor and lay a plywood subfloor down.
My understanding is that when you have concrete, tile gets layed directly on top of that, am I right?
I suggested that the floor get leveled with a self leveling compound and then tile, I know that will get me up to an inch.
(By the way I will not be doing the floor job, I was there to look at some framing issues – but I would like to give them the correct adivce)
also if he were to build up the floor as much as he is thinking I need to know because it affects the stairs I will be framing.
    IMERC | Jun 30, 2006 09:32pm | #1
    chip awat the really bad spots...
    float the not so bad...
    tile straight to that...
    WOW!!! What a Ride!
    1. alrightythen | Jun 30, 2006 09:34pm | #2
      That's what I thought too.
        IMERC | Jun 30, 2006 09:38pm | #3
        post the pics when yur done...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
        LEMONJELLO | Jun 30, 2006 09:40pm | #4
        yup, either that or self levelling compound, Tape along the base of walls and holes to keep the mix from going where you dont want it to go.__________________________
        Judo Chop!
  2. WayneL5 | Jul 01, 2006 01:51am | #5
    If there are any really high lumps, chip them off.  Then use self leveling compound.  It works well.  You must follow the directions for mixing carefully -- measure the water and add exactly what they specify.  Don't guess or mix by eye.
    1. jrnbj | Jul 01, 2006 11:35pm | #6
      Self leveling is a bit of a misnomer......a good aluminum extrusion screed is a necessary with the usual compounds....the real self-leveling gypcrete isn't something I'd use in a basement slab application.....
      1. FastEddie | Jul 02, 2006 12:23am | #7
        Ditto Imerc.
        Self-leveling does work as advertised.  But the problem is that it develops a pancake-batter leading edge, so you have to work that a little.  But the stuff behind the edge does self-level.
        IMERC | Jul 03, 2006 03:20am | #8
        A darby is easier than a screed...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
A New Approach to Foundations
