Tile Floor
| Posted in Construction Techniques on May 9, 2005 04:39am
I have a floor in a comercial retail store that I have to retile . The existing floor is in so so shape, vinyl squares (some dimples and some cracks). Asbestos is not a concern. I would like to tile over the existing tiles but have my concerns about the high points and voids, Is this a good idea or should I remove the old floor and start over?
  1. FastEddie1 | May 09, 2005 06:18am | #1
    What will the new tile be ... ceramic or vinyl?  How much time do you have to do the job?
    There are floor levelers available that set up in 30 minutes and are designed for small dings and spalls.  High spots should be chipped or ground smooth.  Other than that, you can tile over the old stuff if you use the right material.
    maddog3 | May 09, 2005 06:53am | #2
    I just finished at a large 24 hr.grocery store 80-100k SF.
    The tile setters re-tiled the whole thing over the existing,
    working 6 hrs a night..... ( non-peak ). they did nothing special except use some kind of fast set ..filler? The problem they had resulted from bouncing around the store every night on the perimeter to follow the fixture guys. the whole store was a checkerboard pattern and they had to match something that was 350ft away from the night before., these guys were not happy the first few weeks
Tool Test: You Need a Drywall Sander
We tried out a range of rotary and random-orbit sanders to compare their dust collection, quality of finish, and user fatigue after hours of sanding.
Start your subscription today and save up to 81%
